Hi all
Now to start i'm not sure if this is an actual sensor fault. I checked the tyre pressure at the garage using the air and set it to 30psi a few days ago, however now the car is telling me it 23-24psi and needs inflating. So I went to the garage again and its was showing on their display at 28psi.
It seems that 1psi drop in the tyre shows about a 3psi drop on the sensor. I've also checked and there is nothing visible to lead me to believe its a puncture.
I know these are around the ÂŁ50 mark and there are 2 types of which I don't know what mine has. Are they easy enough to replace yourself? The car is a 65 plate Sri id that helps. Obviously I don't want to be spending money unnecessarily so any advice would be appreciated.
